VWDMC I'm in the mood to chat!
I'll throw the idea to the friends bulding the kits, I'm not in the business (was in the 90's)...but TheSamba sounds like a good starting point. What I would like to do is spread the news, the knowledge and help you guys avoid the mistakes we made. Like I said before, we came a long way. The turbo craze started in Brazil in the 80's, got really serious in the 90's, but we have recently mastered its use. Once you realize the fuel consumption needs, then its the higway to pleasure and free power. If the guy with the MASSIVE 3 liter spanks you with his 280hp screamer when you were running 15psi on that lazy wednesday night, you tell your engine builder, retard timming a little, step up 10 on your mains and simply bump the wind to 30psi and voila, you just made 100 and something free horses. Do they explode? Yeah they do, but that's up to you (what I mean is that there is no black magic in them). Great part of the blowing up is due to lean conditions, and they are due to improper tuning. I've been doing this for the past 17 years and I threw more valvetrains in normally aspirated engines due to stupid driving tha thrown rods due to weak bottom ends in turbo engines. I've had a lot more demage done due to lean condition, but that is part of the past and in any case, they are usually nothing more than a burnt head gasket (watercooled VWs). Alcohol is awesome, I urge you guys to switch, whenever you have it readily available. The engine stays much cleaner inside, that alone is a great advantage. It is incredibly cooler, I'm mean my bug runs 13:1 CR without an internal cooler only the 72 pass external with no fan, and the car never sees past 90 degrees. And obviously, more CR means more power. Brazil went to alcohol in the 70s I think because of the great oil dependency we had, with the crisis and enough land to grow sugar cane, it was an obvious solution I guess. In the biggining the cars sucked, they did not have good cold start systems and the CR wasn't bumped up, so they were extremely hard to start (for a normal driver) and fuel consumption was terrible. Once compression was up and they developed automated cold start systems, the sales took off, to the point that in the late 80s, 98% of the new cars ran on alcohol. For some stupid reason the government abandoned the program in the 90s and we had some shortage then. Later when the market opened up, imported cars were solely gas and the factories stopped developing alcohol engine, so you had a surplus of the fuel, which was great for us. I remmenber having a 400hp daily driven Rabbit that cost half to run than my dad's 115hp Passat. Those days are gone though since recently the manufactures started building the flex fuel cars, which run on either fuel. Regarding the parts and secrets, I'd be glad to list them here, but I don't want to clog your pages so, if it is of anyones interest, let me know. Regards to all, Marcelo |
Hey, this thread is interesting
If we're talking reliability rather than max HP, lets say this engine you're talking about but with maybe 150-180 HP rather than 300? How reliable would you say such a setup would be, if used as a driver/fun road car rather than racing?
Type 1 -69 in Gothenburg, Sweden 70's German Look in the making |
dubKustom,
Hello! Yeah its pretty cool heh? Well, like I said before (maybe not here), I fail to understand the reliability problems you guys complain and talk so much about, specially in the T1 motors. There are things that you have to correct in these engines which were things that in a high performance application didn't work, such as lack of oil filter, cooler right in front of 3rd cylinder and so on. We do not build fast engines to last 100.000 miles, that is just not something we worry about, specially because there are other things that happen during the life of the engine that ultimately makes you loose a few horses gradually and you would eventually tear down the engine to fix these things before that period anyways (such as that nasty black build up on the top of the piston which I don't know how you call it, or worn valve guides or pistons that shrunk - have you checked how much a forged piston shrinks after some hard driving and so on). So the engine gets old. Worn out, and it simply doesnot deliver the performance it should. A properly tuned 300hp 1600 will last a long time, a 180hp one will probably last longer, but it doesn't matter how. I had a daily driven Rabbit with 400+hp for like 50.000, tore it down because it leaked oil everywhere. I replaced the rings (the leaks were due to excessive pressure in the sump due to ring leak down - the car did not use an air filter due to lack of space in this specific set up), replaced the gaskets and seals, and headed to another 50.000 miles, a friend still has the car, going strong after maybe 10 years of driving. My point being, reliability is not a problem if properly tuned. Keep in mind that turbo engines have low static compression and easy-on-the-parts valvetrain, it is essentially a stock engine off-boost, so it will last a long time, much longer than a wild arse normally aspirated engine, when driven under the conditions you described. On road racing applications the story is different because of heat build up. We have recently put together a road race Fox (remember the old ones made in Brazil, sold in the US, the ones you hated), the car has a conservative 300hp on 15psi and we are getting spanked by heat. Everything under the hood is melting, started, hoses, wastegates.....but we are learning, so I guess even in this case, once you learned how to cool the whole thing down, it will be ok. We went the whole last season on a STOCK engine (stock pistons and rods) running 270hp with the same boost and more fuel, just to understand how far a set of factory pistons and rods will go. TO sum it up....careful when people say that this and that CAN"T take this or that....they usually can take a lot more than what people thing, but the problem is that usually there is something wrong elsewhere that prevents the whole thing from working properly. Additionally, people insist on building mega horsepower engines (180 on a bug is mega - factory is what 50?) using factory tolerances, oil pressures and volumes...things like that, those things play a maker role in reliability also....factory tolerances on a 8000rpm engine won't work. So to answer you question....don't worry about reliability on your application, if tuned properly and a few things observed, it should outlast your paint job, wire harness, and definetely your tires..... Best regards, Marcelo |
OK, I see your point... I don't know that much about VW engines, still in the process of learning, but what you're saying almost sounds a bit too good to be true
All the people I've spoken to, including a few drag racers in my club are basically saying that lots of HP in a Type1 engine will make it a lot less reliable. It seems to me (from what all these people tell me) that in making a high performance T1 engine you will either lose reliability or you have to spend a fortune on it, basically building a brand new engine with aftermarket parts... My long-term goal is to have a kustom Bug with a solid, high performance engine to use as a fun street/highway driver. But I don't want to get stuck on the road all the time, so I have considered swapping to a tuned Type 4 engine or an all-out conversion to a newer engine like a Mazda rotary. I mean, if I could keep the "stock" engine, get good horsepower AND be sure to get home without a hassle, no one would be happier than me But until now that has seemed impossible.Am I talking to the wrong people, like drag racers who will do anything to cut their 1/4 mile times, rather than building usable street engines? Thanx/Daniel
Hey 1500SBR
i'd like to know more details on the engine hardware for all-out and moderate power (130+/-HP), PM or Email me Ok?
well our good buddy Marcelo has made the speech about how to get the power we've heard about, so here it is:
YOu asked for a run in the parts needed, that's a long answer question, but we'll go in parts, you keep coming back with whatever I fail to answer. Keep in mind the following: We had beetles here up until 1996 and aircooled Buses up until last year (or this year, I don't care much for the new buses). This means two things. I don't know if there were any changes, I can't tell you if the 96 brazilian engine is better than a 70 German one. I know it is newer and that alone is a big difference. So even though both are STOCK engines, the newer engine will be stronger (it will probably pass magnaflux tests, while the other may not). But lets say you are starting with a zero miles engine, completely stock, these are the mods I feel are necessary: OIL - External filter, high volume pump, external cooler (72 pass) with scoop next to the tranny - no need for fan, unless you guys get higher temperatures that Rio de Janeiro Cooling - Fan shrould without oil cooler, all tin in good condition and seals in place - You want the heat outside the engine bay, the engine cannot recycle heat - A doghouse places the cooler outside the shrould, but the friggin cooler is still in the bay, when you stop the heat radiates around the bay and the fan sucks the heat - No open hoods either. If you decide you need extra cooling in the bay, has to come from the bottom of the car and from the front of the rear axles- any air pick ups from the back of the axles to the back of the car has a higher temperature on a running car. IGNITION - obviously points won't work, anything electronic. In Brazil we use electronic or Hal distributors with stock ignition boxes and coils. MSD systems are not necessary, but you may not have access to a Hal or factory electronic system and might want to use whatever you have to eliminate points - Pertronix type of thing, I don't know, never used it Fuel delivery - Electric fuel pump that flows at least 1 gallon a minute will work, must do so at at least 60psi. Pressure dependant fuel regulator with a line returning to the tank (or before the pump pick up) - pressure set at idle will be rougly 5psi and it must raise pressure in the same rate of boost (with 15psi of boost you will then have 20psi of fuel pressure - you will read this pressure after the regulator and before the carburator) - If using carbs, you will need big float needles. Turbo Kit - there is a more common manifold where the tubes go up and the turbo sits next to the alternator, don't use that one, there is a CB Performance one where the turbo sits next to the crank pulley and they remove the rear tin - don't use that one either - the ticket is a kit where the turbo sits right above one of the axles, high enough to have the oil from the turbo returning by gravity only - the reason to chosse this manifold is to keep heat away from the engine bay - all tubes should be thermally wrapped. Additionally, the up pipe should route to the carbs in a T fashion (where it splits for both carbs, rather than a Y fashion). Y seems better for flow, but in practical terms you may get more airflow to one of the sides, while using a T, it is harder for this to happen. Nobody uses an intercooler, but I would not put one together without it....next to the tranny with a scoop Turbo size - Depends on the application - exactly like a cam. Use a T2 style for up to 150hp, T3 style with AR .42 for the compressor for up to 300hp. Larger turbos, will only work with bigger engines or 8000rpm screamers. The exhaust side shold be a AR.36 or smaller for low hp applications and AR.48 on the other ones - wheel size, I don't have the spec sheets with me, can tell you later though if you get serious - regarding TRIM, we don't have a choice of trim here (we do, but I'm not that sofisticated and haven't gone into that - it makes a difference, but you are talkging 200rpms up or down and 5hp up or down) - To hell with TRIM. Carbs - on a 150hp applicationn - Dual 32s. bigger carbs will make more power, dual 40 or fuel injection better (can't really help you with tuning the 32, cause I dont use them, can help you with the 40s and 44s) Ok, basics layd down, now the variables. A stock motor described above with 32s and a T2 should make in the neighborhood of 130hp with 15psi. But it will spin past the stock springs capability, so you wanna have a set of high performance single springs. Otherwise, rods, pistons and all are safe. Now when it comes to making more power (remember they make 300 on Fuel injection, with 4 40mm throtles). The following is a list of things that will help a lot. Obviously the size of the throttles. dual Weber 40s will make a huge difference, and you be able to step to a T3 turbo (more air volume on the same boost level) without a enourmous amount of lag added. But when you get there, higher revs are on the way. you need valvetrain upgrade - pushrods, springs (single or dual if more than 6500), retainers, things like that. Next would be large valves, 40X35.5, a 3 angle valve job and mild port work. and next an Engle TCS 10 with the dual springs. The cam could come before the valves, but then you would have split the case. Remember, this is using stock rods and crank. You might have a problem with the flywheel without the 8 dowell, but that will depend on your driving. First time it comes loose you will have to step to the 8 dowell thingy. Of course, the stock clutch can't take the weakest of turbo set ups. Clutch you use whatever you have there. I normally run ceramic discs with stock pressure plates, they vibrate while taking off a little, but I get an original pedal feel, as oposed to start having problems because of the added load on the pedal (mainly the hassle in traffic). SO to answer you question in one line - 130 hp, all stock, with T2 turbo, single high rev springs on dual 32s (and no points) - More than that, step to Weber 44s and a T3. To be safe (of the drivers mistakes) upgraded valvetrain. Still want more, nice set of heads with mild ports and 40X35.5 valves. You can drop this at the thread. It will be nice to hear the IMPOSSIBLE, NO CAN DO, EVERYTHING WILL BE FLYING comments....but unless there is some type of magnetic field in Brazil that prevents the engines from flying apart, that's how they work over here....eventually you get to break something, but then again, the 45hp ones also break. It is not uncommon to see the people here complain about reliability, but when you look at their engines (don't even have to take them apart) you realise the reliability problems come from the fact that they are using old parts, bad assembled parts or a combination of both. Other thing I wanted to tell you....we have a racing league here called Speed 1600 for bugs. They run 14 inch stock rims (from Brasilia and SP2) with radial tires. Some 5 degress of camber in the front and like 7 in the back, roll cage and stock motors. You are allowed only to work on the 32s, increase CR, some port and angle job, valve springs (I think) and the use of a 4X2 header. The suckers make 110hp. 1600, stock cam, stock heads, stock everything....they spin to 6000rpm. The only real problem they have is that they leak so much oil that they have to be the last category of the day or else the other guys complain about the dirty track....true story. Regards, Marcelo well there you have it people, so you can see it really isn't that hard but forgetting to beef up a simple parts or not putting the fuel delivery together right will make the motor go kaput so will anybody here want to try this? |
Yep, I'm game to give it a shot!
I'm putting together the bottom end of a 1600 as we speak. its tapped for full flow oil, has a windage tray etc... I also have a T2 turbo and complete CIS injection system waiting to be chopped up and fitted on. I'm interested to hear or see (if you have some pics) how you run all your oil lines to and from the cooler and turbocharger? |
