  #26
Old July 18th 2006, 14:23
EvilOval EvilOval is offline
Its not that hard to do....once you have an idea of what you want it to look like. I've never used fiberglass in my life. But after purchasing a very ill fitting 911 shroud I ended up learning as I've gone. And while I've had a few setbacks here and there.....its been a fun experience. Anyways, here is a pic of the dash as it was 2 weeks ago (I'm working on the cover panel that will fit below the steering column).
http://www.thesamba.com/vw/forum/alb...?pic_id=289070
Once the general shape is complete I'll go back over it and make some adjustments here and there before I create a mold of it. Once I've made the mold I'll make 3 of them. The 1st one will be used to figure out reinforcement points as well as the glove box. The second one will be a finished unit with CF accents at certain points and what isn't CF will be painted to match the body. The final one will be completely CF. I might be making a 1303 version since a friend of mine was asking if I could use his dash as the pattern and then modify it to house the 911's cluster. So, that might be another form that I have laying around till I get my own 1303.
72' 1302 Vert GL (T4 powered money pit)
69' Ghia GL (T1 turbo powered and in pieces)
