Old July 18th 2006, 13:32
oasis's Avatar
oasis oasis is offline
oil pressure gauge
I see VDO gauges for oil pressure go to 80, 100, and 150 PSI. What is the ideal pressure for a 2056 T4 engine (naturally aspirated, nothing too fancy)? What gauge should I have an interest in?
Old July 18th 2006, 21:52
The 80 psi one should work fine. But IMO feel you should be asking Jake. There are alot of factors; year case, lifters, oil pump, O/P relief set-up, you know, the basics . Seriously though, I read a post on STF about this. Jake said " 40 psi is more than enough pressure at RPM for most combos. Above that you start to take HP away."
Old July 18th 2006, 23:06
oasis's Avatar
Jake had me measuring the rear wheels in the rain earlier tonight. Different issue.
Thanks for the reply. I'm there.
