Old September 18th 2006, 05:17
Eliasson Eliasson is offline
Torsion bar
I pushed some wrong buttons before I was ready to send the last message. But here I try again.
I put a list together, with what I found availably torsion bars....
Car model year Dia (mm) Note Art.number
924, Typ1 76-80 22 /L 311 511 115 D
924, Typ1 76-80 22 /R 311 511 115 D
924S2 86-88 23,5 /L 944 333 115 00
944 82-92 23,5
924S2 86-88 23,5 /R 944 333 116 00
944 82-92 23,5
944S2 89-91 24 /L 944 333 115 01
944S2 89-91 24 /R 944 333 116 01
944,M030 -86 24,5 /L 944 333 103 00
944,M030 -86 24,5 /R 944 333 104 00
944T -92 25.5 /L 951 333 103 30
S2,M030 87-
/M031
/758
968 92-95
944T -92 25.5 /L 951 333 104 30
S2,M030 87-
/M031
/758
968 92-95
I use 23,5 mm and lowering angle 12 degrees and that works ok.
Old September 18th 2006, 05:35
Lenght and number of splines
Hi again
I found that the lenght should be 676mm.
Inner splines 40 and gives a change of 9 degrees
Outer splinses 44 and gives a change of 8º 10,5’.
Old September 20th 2006, 00:32
Humble's Avatar
Humble Humble is offline
Zen, I'm running the 944 25.5mm torsion bars which were a good mix of track and street. It's on the tight side for street use but if you autox, hit track days, or frequently drive winding roads the setup is perfect. It never had any problem with my type 4 hanging off the back.
My old track/street setup
72 super
2L type 4
1303 lower control arms
modified 944 struts with kyb gr-2 inserts and eibach 12" 80lb/in. springs
86 944 n/a alu arms
86 944 club sport 25.5mm torsion bars
kyb gas-a-just shocks
6x16 fuchs w/ 205/55R16 potenza s-03
7x16 fuchs w/ 225/50R16 BFG GeForce T/A KD
Old October 16th 2006, 14:19
OldeFahrt's Avatar
OldeFahrt OldeFahrt is offline
I had the same question so I made a shot in the dark. I just put Sway-A-Way 28mm's on thinking they would be super stiff. (aircooled.net) I autocross so I was willing to sacrifice some comfort. No comfort lost. The car now feels solid & firm, no harshness at all. Red Koni's too, on second setting. Magic Carpet. I'm kicking it at the autocross now too. Just what the doktor ordered.
Aircooled Road Racers
www.shoptalkforums.com/viewtopic.php?p=768795#768795
