Old September 20th 2006, 19:15
zeroaxe zeroaxe is offline
Ricola,
Thanks for the tip. Yeah, I wouldnt have used a 12mm stud/lug nut if the hole in the wheel was 14mm for example. Just if I had the option to use 12mm studs/lug nuts, I would've made sure that I had a wheel to suit. But thanks anyway for reminding me.
As you say about the press studs. someone else also said that they dont need to be press fitted. "Just fit them and bolt them down" I was told. I would need to know the hole size(Down to the Micro reading) to make sure the holes arent drilled too big. I would've thought that 13.5mm or so would be the right size?
Thanks for posting.
BTW, fantastic progress that you made/are making on the Phantom!!
