Humble, I have a question. I saw where the cross brace you made attaches to the body. Is it welded? That is going to be very difficult to remove the transmission, if it is welded. You could weld your brace to a plate, then weld another plate to the body. 1/4" is probably be as thick as I'd go. Then you can bolt the two plates together. Also you can come in and tie your cage to the rear brace you made, to where it's removeable without removing the whole cage.
I was also wondering about your transmission. The trasmision is going to want to twist. Do you think those two bolts on the top will be enough? It's going to want to sheer them off. Maybe a strap over the tranny and tie the bottom into the frame horns?? You'll be grateful in the end if you make as many parts as you can removable with out an arm and a leg. If you need a visual of these I can take a picture of what I'm talking about. Or kinda draw one with paint. It's looking good. I see a lot of good ideas being used. Keep up the good work.
| Currently Active Users Viewing This Thread: 6 (0 members and 6 guests) | |
