where r u ppl, this problem driving me mad
Don't know if this will help, but check that the axle nuts are the correct tightness, as well, all the pivot points should be checked:
Tie rod ends Lower control arm bushing Strut balljoint Replace anything that is worn. After that, I don't know what to tell ya. Jason
Your shimmie is a rarer one!
Check all of the above as well as the joints in the steering. Pay particular attention to the idler bushings and steering box. It appears there is no single component that goes bad and causes the 'shimmies'.. Slop in the steering combined with general wear in all the joints. Bad front and rear shock absorbers, collapsed rear springplate bushes, sagging rear torsion bars will all add up and will cost you front castor. Is your suspension modified? Any play in the steering? What was your wheel alignment set to? The stock wheel alignment settings require everything be in A1 condition, wheel camber zero crossing during driving will change the loading/direction of loading on the steering joints, any slack and there is a shimmie. SuperBeetle wheel alignment is EVERYTHING, when our cars perishable parts get old, the optimum wheel alignment changes as you drive. Pinpointing one component and replacing it may feel like it's sorted- but it may not go the distance and/or something else will go really bad as a result. Matt
'79 Karmann, Nrburgring or bust... |
no, it's a bare stocker with only a gia brake disc system.
but however there is somthing strange during steering; first, it does not automaticly turn straight after taking a turn,,, second, i feel some points in the steering radius wich feels like "stop points", but it continue after this points, 1 or 2 points per side steering... Quote:
...i didn't change any bushings or any part in the front from +3 years ago, but i will when there's nothing else solve it... Michael |
I wouldn't drive it like that.. Those 'notches' in the steering sound like a universal joint of the lower steering shaft galling/freezing up. Get it fixed mate. That is unlikely to be your whole problem like I said.
and i don't know what is this part exactly, and where it is located, plz i need any pics or more details about it.sorry, but as i said i'm not so good in english so i don't know what do you mean by that, do u mean that this is could be my "main" problem of hard steering and notches and maybe my shimmie too,, or it's not? i'm so sorry for my questions but i said before that you ppl here and on shoptalkforums are my only reference of my bug. thank's for your help... Michael |
Your English is as good as mine. This is what I think is bad on your steering: http://www2.cip1.com/ProductDetails....D415%2D951%2DB If you have not tried to adjust the steering box...? Don't do that by the way.
I believe you have other problems. There is almost no place on Earth where nobody is familiar with Bugs, try to find an oldtimer mechanic if you need some help. Matt
'79 Karmann, Nrburgring or bust... Last edited by MattKab; September 28th 2006 at 21:11. |
