Old October 17th 2006, 18:07
i'm pretty sure i got mine from CIP1. i think BugPack makes some Urethane ones which you should be able to find just about anywhere. here are some from aircooled.net.
Old October 18th 2006, 08:24
OldeFahrt's Avatar
OldeFahrt OldeFahrt is offline
Are you saying "Diagonal Arm" bushings? They are also available from aircooled.net. Otherwise, "spring plate" bushings come 4 to a set. 2 inner, 2 outer and mount on each side of the spring plate at the torsion bar "cap." The diagonal arm bushings mount in the pivot where the 17 mm socket head "fitted" screw is, more inboard & close to the torsion bar anchor in the middle of the car but on the outside-rear of the torsion housing. $18.95 from AC.net. Part # SSG0004.
Aircooled Road Racers
www.shoptalkforums.com/viewtopic.php?p=768795#768795
