Old October 24th 2006, 02:39
Eliasson Eliasson is offline
e-brake
Hello
I used the original e-brake cable from 1302/3. I cut off the bar between the sides, and drilled a hole. You see the result in the picture.
It has work so far.
// Eliasson
Old November 16th 2006, 21:38
64bug's Avatar
64bug 64bug is offline
i tried to do the same thing, but it didn't leave me with enough material. (comfortably anyway.) seems like it wouldn't last that long.
Old November 17th 2006, 14:19
buggyboyshane buggyboyshane is offline
guys how did you mount the disks and calipers on the rear. i have the full setup inc rear handbrake bits from a 2003 3.2 's' boxster, and am wondering do i need to make a plate to attach onto the end of the rear axle where the bearing housing goes, around which my handbrake shoes can sit or wha....?
Old November 17th 2006, 16:18
You need the other bits from an early 944 or 924s..
Rich
Old November 24th 2006, 17:52
what other bits rich?
Old November 24th 2006, 18:52
Bullyboy Bullyboy is offline
#23 attaches your brakes to the beetle trailing arm
Old November 24th 2006, 22:16
64bug's Avatar
yep you need all that. Thats the single piston set up but it shows how it goes together.
