Old October 29th 2006, 16:17
Post
The front suspension is either trailing arm or strut, the trailing arm has either link-pin pivots or ball-joint pivots, the strut has a few changes, but it's either one or the other.
Jeff is just bitter because I'm not making him one for his bus! Ok, fine, I'm not rushed.
Old November 8th 2006, 00:25
Bugger Bugger is offline
Thanks, I bought a 1974 with a 1600 dual port engine. I am stoked. I have changed my plans however, while playing around on this site I have decided that the german look is sweet, so I am going for that. I am going to try and fuel inject it and possibly put a turbo on it. I will post updates when I do anything cool, like the fuel injection which should be starting soon (within the next month) I would like to get it done over christmas break, I am an engineering student, so that is when I will have some time and an extra car to drive around. I will try and build all the parts in my spare time (i work at a machine shop), so i will just have to install it over the break.
Old November 9th 2006, 12:37
MikeVW's Avatar
MikeVW MikeVW is offline
Good luck and keep us updated.
Mike
Jack of all trades and master of none!
http://www.Type1R.com
Old November 9th 2006, 13:42
Are you going to use something like a MegaSquirt for you're FI so you can update it to turbo later?
Old November 13th 2006, 08:52
yep, megasquirt is the plan. I want to use verion 2 so it can contol the timing advance etc. I started a new thread in the engine section called cheap fuel injection, and I will keep you all updated.
