Well, there is a difference in bolt patterns, but no offset, and the VW plates on IRS models have a double plate. I'm using the 944 plates, but have all the old stuff I took off for reference if needed.
well it sounds like the Eagle Performance plates will work fine then. I communicated with terry from eagle yesterday and all he needs is a sketch of the bolt pattern if there is no offset. thanks for your help. Your car looks good :agree: .
BTW: kinda funny how we both have 70 standards with 87 994t rear arms.
70 Std. Beetle 03 20th Annv. GTI |
Thanks. Oh, and don't forget to put a type IV in the back of that bug too!!
Levi,
Out of curiosity will your talking with Eagle (Terry) result in a 944 based application? This would definitely fill a void in low cost coilover conversions.. Let us know and continue to keep us posted VR ALex
wrenchnride: I currently have a KO3s turbo from a passat that i plan on using with an 034EFI EMS.
That should scoot you down the road!
I also have the eagle kit. and I also have
1983 steel 944 trailing arms (same as vw) 1985 aluminum "951" trailing arms (turbo) stock vw trailing arm. I was just gonna make new spring plates from an old set of 911 ones I had If I used the alu arms....but what I wanna know is how are people bolting the alu 944 arms on? the bushing is wider, just use washers and a longer skinnier bolt?? or are people welding on diff. brackets?? I might just end up with the early stell 944 stuff so I can narrow them.....so I can fit the 16x7's on a notchback |
