Old January 13th 2007, 11:11
Veedub Veedub is offline
Fuchs are crazy in prices I'll go back to the 4-100 plan...
I think I basically decided I want a rim in the 14-16lb range. Anyone know if the stock 60hp motor can handle moving 15x7inch rims?
The wheels Im most likely going to get are Rota Slipstreams,ASA AR1's (there like oasis's rims)see link.
http://www.tirerack.com/wheels/Wheel...ber=AR15I22SML
or OZ Canova see link
http://www.tirerack.com/wheels/Wheel...0&autoModClar=
these are the 3 I mostly like, but cant decide.
Rotas got a 40mm offset,ASA AR1's have a 40mm offset and the OZ have a 45mm offset.
What rim would be best to use and require less modifications for the rear?
The front I know narrowing 2-3inches will be required along with drop spindles.
