Old February 8th 2007, 17:17
fastdub fastdub is offline
Originally Posted by Veedub View Post
But theres a porsche version so
dont make em gl
and im not sure there is
Old February 8th 2007, 17:43
EvilAngel's Avatar
EvilAngel EvilAngel is offline
AFAIK those only came with special edition bugs. But i may be wrong...
________________________
1990 Mex-Spec GL Bug "The Blue Flame":
Engine: Planning Stage
Transmission: Planning Stage
Suspension: Front: 3/4 swaybar w/UrethaneBushings, Dropped Spindles. Rear:CB Camber Compensator. Lowered 2 splines
Brakes: Front Brakes: 280mm solid rotors, two pot calipers. Rear: 280mm solid rotors, 1 pot calipers w/ebrake
Old February 8th 2007, 17:50
Pillow's Avatar
Pillow Pillow is offline
I would not consider them GL either.
Actually I do not think they look good at all. PLus they are so skinny you cannot fit decent meats on them!
Adrian Pillow
'57 Oval Beetle - project
'66 VW Westfalia - GL
'99 GMC Suburban 6.5L Diesel
VolkSport Kafer Gruppe
Old February 8th 2007, 21:07
yeah stock wide ones look **** loads better
Old February 8th 2007, 22:23
Veedub Veedub is offline
They were also available on the 914's. The 914's had a 41mm opffset, the ones for the beetle had a 27mm offset. Guy on thesamba told me.
Old February 8th 2007, 22:28
EvilAngel's Avatar
That would mean the 914's are wider (right?) Other than the look, which shouldn't mind since your car isn't a strict GL, the problem is that they can only accomodate skinny tires, as mentioned above.
Old February 8th 2007, 22:33
Well the ones for the 914 wont work on a bug at all. If skinny tires can only be runb on them Im not gonna go that route then.I was gettin a set of 4 for free.
15x5.5's but i wont now But I dont understand why you couldnt run a wider tire on them, oh well.
Old February 8th 2007, 23:41
Timmy_Barns's Avatar
Timmy_Barns Timmy_Barns is offline
Kinda off-topic, but are Fuchs considered GL?
99 Mk3 Jetta
Don't take life seriously because you can't come out of it alive" --Warren Miller
Old February 8th 2007, 23:51
I think they can be considered GL or CL, depending on whats done to the car, my car follows no look really
