Go Back   GermanLook Forums > Classifieds > Wanted
Old May 4th 2007, 13:18
AggieDave AggieDave is offline
Its basically like a Hurst Shifter. As I understand it, they're quite expensive for the original VW option, BUT you could make one using a shifter stick from Hurst.
http://www.hurst-shifters.com/shifter-sticks.asp
It would be incredibly easy to make using a stock assembly and modifying it. All the cuts and welds (or bolts) would be covered by an aftermarket shift boot. You could put whatever you want for the shiftknob.
Old May 15th 2007, 08:01
redhot redhot is offline
Its just a kind of obsession with the original
Otherwise I guess I`d just buy a new one from CSP.
Old May 15th 2007, 08:30
oasis's Avatar
oasis oasis is offline
You are focused on what you want. Sounds like a good kind of obsession to me. If I see one in my surf-abouts, I'll let you know.
I do like my CSP though.
(2004-2008): 1971 1302 w/2056
Old July 11th 2007, 10:25
Up to the top.
Also: do all agree that the CSP shifter is as nice as I have the impression it is? Want the ball style knob.- But what type of lockout? Does other shift-knobs fit straight on?
Old July 12th 2007, 10:54
oasis's Avatar
I am unanimous in liking mine.
Here is the link for selecting the shifter you want through CSP. You will notice the butterfly is the only choice with a ball knob.
I have not tried to remove the ball knob so I don't know about thread size or anything like that.
