Old May 8th 2007, 20:39
Danborn's Avatar
Danborn Danborn is offline
Oettinger WBX
Sadly I have to sell my Oettinger 2500E WBX..
Here is a linkhttp://www.thesamba.com/vw/classifie....php?id=452405
Old May 11th 2007, 08:43
Danborn's Avatar
The engine is complete with all you need, as a longblock with all the injection parts, water pump and Flywheel, except for the camshaft, lifters. And bearings. Any 270- 284 Type-1 cam will work fine, it has solid/mechanical lifters, the bearings are std. 2,1 WBX bearings so it should not be a problem!
I don’t know why Oettinger used solid lifters in there engine but I’m sure it for a reason!
The Crank is very fine with standard measurements. The case *** well. There is brand new pistons rings (worth 370£)
One new piston and cylinder, the other 3 are fine!
I was thinking in the neighborhood of 3000£ but I am open to offers!
And I will ship Worldwide..
Cheers Jesper
