I'm having 034 build a harness for me, I think it actually uses the stock H2O temp sensor so that is taken care of, and then I can just set what temp I want it to come on at.
Pulled the motor and tranny out for the last time. Wanted to make sure everything inside the clutch was buttoned up OK, found that I had forgotten to tighten the bolts on the driver side CV!!! Double checking is a good idea apparently.... Welded up the gaping holes where I cut the frame horns off at the torsion tube. Engine back in then wait till new harness and throttle cable arrive from 034... Jason
Ordered this sucker today:
Hargett Precision Throttle Pedal I think it is an excellent product for the money. I was planning on just building one myself, but at the rate I've been going I figured I better not mess around!!! I think I'll be building the actual pedal surface myself though, so it's exactly what I want. Check out the shifters they have too, pretty gorgeous. Just need to figure out how to connect this with the stock VW 1.8t throttle cable now, some sort of extension I guess... Jason
If I could just get paid for my sleepless nights.... 1960 VW Bug UBRDUB Walkaround 1st Drag Run Dyno Run Oval Ragster-'57 Rag/'04 Boxster S Last edited by volkdent; October 27th 2007 at 02:47. |
Is the 1.8 throttle push or pull? Can you run morse all the way with an adapter right at the throttle body?
I had to build a swing lever to convert mine from push to pull (buses are already that way but I had to reconfig most of it) and spent some time figuring out the geometry to get wot. Are you sure you dont want to try DBW? Somebody needs to be a test case and tell me how hard it is.:devil: Jeff-
No current VW projects 54 Chevy wagon LS2 AWD 56 Chevy Panel "Lost Cause" VKG Bastage child |
It's pull, I think it will be fairly easy and adjustable, but of course it's easy to say now!!!
DBW huh, sounds great!!! ![]() Jason
Ok, you got me. What is the prob with the drive by wire setup? Is it the delay? or the size of the TB? Why no big power?
I guess I just figured with it getting so common now, they would have kits developed for even doofuses like me. DBW for dummies. Jeff-
![]() Jason
Waiting on a custom wiring harness now from 034. He has all the info and apparently it's just a couple days from being done. Looking back it seems like I've been waiting for wiring harnesses for half of this build!!!
Got the shifter cables back in and the brackets aligned better. Hard to believe I first hooked up the cables 3+ years ago!!! Anyway, making the brackets strong, they were just tacked up before to make sure it would actually work, and partially removable, to remove the engine the bracket needs to be partially removed. I'm off for 5 days after tomorrow, so I hope to get the fuel system purged and the wiring done, that is if the harness turns up... fingers crossed! Jason
Dent,
Let us know how this works out. I'm sick of dicking around with the stock pedal trying to get WOT. Will you be using the stock brake/clutch pedal with this setup ? Won't the original setup be 'in the way' of the new pedal ? Panel, Do you have any pics of the lever you created to increase the travel of the cable ? Thanks, Rob. Quote:
Well, it didn't actually work out so well. It turns out the quality control on the pedal's manufacturer has slipped way out of control. The breaks were not perpendicular, the hole tolerances were way off, there was 3/8ths of lateral slop at the pedal top. I emailed Mark Hargett and he agreed, so I'll be returning it. I think he designed it, but then has someone manufacture it for him. Sounds like he's going to be addressing the problems pronto., so it should be a good product again in the future. I'm going to return it, but not before I get all the dimensions down, modify it, and build one myself that works for the bug application. If I want then, I can buy his pedal covers, they do look pretty sweet. I'll copy that design if someone is interested.
Rob, if you go to the brake section, the thread "Let there be brakes", you'll see the pedal cluster I'm using. Jason
