Old October 31st 2007, 21:44
For a T4 up to 180 ft lbs - stock 914 215mm fw/pp/clutch
I used a 228mm wasser fw/Kennedy satge 2 pp/ 6 puck solid clutch and could not tell the difference in pedal pressure. You also save a few lbs on the complete setup vs a 215mm setup.
The stock 228mm setup holds 200 ft/lbs, stage 2 pp with stock 228mm clutch holds 273 ft lbs with no increase in pedal pressure over a stock 215mm setup. The 6 puck clutch increases the holding power to 341 ft lbs.
