Old November 14th 2007, 12:02
flat_iv flat_iv is offline
The rear tires are 205/50/16 but are completly wore down so they are more like a 205/45/16. What you really have to worry about is the tire cross section because every tire has a different cross section width. Mine are 8.2 wide and the outside of the tire clears about 1/4" from the fender lip. The inside I had to cut down the bump stops but did not have to relocate the bolt on the control arms. I originally had Rivieras that cleared only 1/8" and never rubbed. The fronts were my main issue bucause the 205/50/16 what are on the back were on the front. The looked great and tucked into the fender well but when you turned the corner and enter the driveway the tire rubber a good bit. I went to a yoko 195/40/16 and have not rubbed any. The tire is a little smaller than I wanted.
