Old December 12th 2007, 09:22
mabbo mabbo is offline
Originally Posted by mabbo View Post
hey guys,
would this work?
if i used a stock vw 4 stud disk or drum machined down to use as a hub with a porker vented disk, then have the 4 stud vw pattern put into the disks. a early 944 caliper and mounting bracket.
i want to keep 15" vw pattern wheels...
cheers
mabbo
can anyone see why this wouldnt work?
vw 4 stud drum or disk machined down to use as a hub
get a 944 disk re-drilled to 4 stud vw pattern
bolt the 944 disk up to the back of the "hub" like Steve C's method
regular 944 mounting bracket and single slider caliper
this should give me vented disks and still use vw 4 stud wheels?
mabbo
