  #16
Old December 25th 2007, 07:17
zeroaxe zeroaxe is offline
Originally Posted by FeralBug View Post
use the stock/factory clips, put them in the stock holes in the door, place some epoxy on the back of the clips, then align the panel into place.
once dried, the panel can be removed and replaced at ease just like the stock vw door panels.
doing it this way eliminates screw holes, giving a clean appearance.
this is how i did it, works perfectly. i hope this is useful.
This actually sounds like a REALY good idea! I am just wondering what you will do if a clip actually BROKE!? I suppose you can put a sander to it and sand it off flush with the panel, and then re-epoxy another one in place. So not bad at all!
Zeroaxe
