Old December 26th 2007, 13:47
mabbo mabbo is offline
i was a little concerned that the golf brakes front and rear would cause the front/rear balance to be out as a golf has all the weight in the front, or would the master cylinder sort this out?
Old December 26th 2007, 21:29
Good point. I suggested the golf in front to keep the brake bias of the "factory matched" set-up. I would check the size of the golf m/c to VW m/c. You could always put a proportional valve in the rear line to get more rear bite.
