Old January 3rd 2008, 04:10
2443TT 2443TT is offline
The wheelbase of the 944 and vw are the same at 2400mm but the wheel track is 200mm less for the vw. This means the ackerman steering angle comes up short.
If you are widening the body at the same time its not a problem. If you go 100mm wider each side your car will be idential to a 944. Problem solved.
Old January 17th 2008, 04:15
punchbuggyracer's Avatar
punchbuggyracer punchbuggyracer is offline
Cheers, I dont know if i can make it that much wider but we'll see. I dont like the idea of bending steering components.
