Old January 8th 2008, 09:32
elev8_dude elev8_dude is offline
Thanks for the response. I will keep an eye out for the Mobil1 filters on my next change. The K&N are a bit pricey in my parts. Thanks
Old January 9th 2008, 13:34
dirk.Gysbrechts's Avatar
dirk.Gysbrechts dirk.Gysbrechts is offline
this problem will be solved with an Oilpumpcover with pressure valve..
Old January 9th 2008, 16:09
Sorry not to familiar with the process and the part. How does it actually go on?
Old January 9th 2008, 16:12
this is my current pump
http://www.cbperformance.com/catalog.asp?ProductID=197
Old January 9th 2008, 16:39
Wenn the engine is cold, and you start, the pressure is too high for the filter. With that oilpumpcover with pressurevalve...the pressurevalve opens at 60 bar pressure and the oil goes back in the case instead of the filter...The picture is an example of an pumpcover made in Germany,but you can also buy it from for example Gene Berg...
