  #18
Old January 18th 2008, 17:45
wrxJim's Avatar
wrxJim wrxJim is offline
Got cracking on the rack conversion yesterday started taking some step by step photos didn't think i would need to cut so much out but least its in there just got to plate up the chassis now and mount the rack on the body.
mccarthy500. I will need to clearance the wings because the engine is higer up than usual the cam belt pulleys will be outside of the bodywork. When i remove the rear mounting for more bracing i will take some more detailed pictures for you. Thanks for the postitive feed back.
