#121
VW 1976 |
#122
Here in Mexico are common made by Hella.
VW 1976 |
#123
Finally after a long time I Start to work on my car again.
I weld the steering to the chassis this is a easy work but the hard work was to find the correct place of the steering to have a descent bump steer and Ackerman effect. Some pics of the Appleton steering: ![]() ![]() ![]() Measuring Bump Steer: ![]() Also I weld mountings for seats (very tight): ![]()
VW 1976 |
#124
Glad to see your back at it again Hugo, keep us updated.
#125
Hi Hugovw1976,
Nice cool ride you are building... That Audi V8 engine and transmission, do you have the mesures for that, the buildt ind mechanical size (wide long and high and mountings are) I am planing to build one midengine vw my self. Kind regards vwgeil |
#126
Hugo how much you spend on your bug?
#127
who cares. good pieces of artwork are priceless
...................( O\ l /O )..................... |
#128
I have to take the measures this weekend because I don't remember.
VW 1976 |
#129
I don't have the numbers, I believe it's better for myself because probably I sick if know how much spend on my car.
VW 1976 |
#130
Can I get you to mesure your frontsuspension arm's to both the upper and the lower arm and the hubs. My plan is to draw everything in 3D first before building it. Klaus |
#131
Here are a couple of measurements from when I was researching an Audi V8 swap:
4.2l engine length: 464mm, 195kg 3.7l engine length: 516mm from front of 4.2 engine to axle line of Audo FWD 5 speed: 25" Hope that helps... Rich
http://www.ricola.co.uk |
#132
Hugo, how bad did the bump steer turn out?
I'm worried that it's not good because the outer pivots on your steering rack are so far outboard of the lower control arm pivot points. Jason
#133
Actully I have to make longer the steering rack (6"). Because with the shorter rack the bumb turn in so bad.
VW 1976 |
#134
Oh good!!! Longer is easier, shorter is not, so that's good. I think you must have a much better concept of suspension geometry than I do, I think I would need a lot of help building a suspension from scratch as you have. Keep us posted.
#135
I hope this illustration help to explain.
VW 1976 |
