Do rockers increase horsepower???
Currently running Scat 1.25 rockers and its time for an upgrade. The reason for the upgrade is that the Scat rockers are worn out and I can't keep a valve adjustment for more than 2 months before it sounds like a diesel truck. If I'm going to upgrade I'd like to get some HP
.For the upgrade, I'm looking at going with CB Performances: Parts List: (1643) Rocker Shaft (1644) Rocker Arms Spacer Kit (1665) Rhino 1.25 Rocker Arms Kit (1642) 9mm Rhino Feet Kit Engine Specs: Vehicle: 1969 VW Beetle Engine: 1915cc (Type 1) Crankshaft: Forged Counter Weighted Cam: C35 Compression: 8.5:1 Heads: 044 Super Mag CNC Round Port Heads w/42 x 37mm S/S valves, 94mm Bore Valves: 40x35 Scat: 1.25 Rockers Carburetors: Dual 44 Webers (w/CB Performance Update Kit) What do the German Look Guru's have to say??? Last edited by elev8_dude; April 15th 2008 at 10:22. |
You need to have a cam that works with the ratio rockers. I believe the scat C35 is for 1:1 stock rockers. The 1.25's are for getting more lift from a STOCK cam. If you use them with anything else you can get the valve wear you are getting.
You will need new valve guides and springs at a minimum.
Oh yeah, forgot to answer the question. Yes, ratio rockers can add HP, but to get longevity, they must be set-up correctly.
My mechanic had said that I needed 1.25. However the cam size you referenced seems very familiar. Thanks for the reply. I'll have to double check my original spec sheet to verify my stated cam size. Any further suggestions are appreciated.
Just wondering, how much more horse power could one gain with rocker upgrades (if done correctly)
Well, about 5 to 10% hp depending on set-up. In the build spec sheet on your first post it said you have a C35, this has slightly less lift and duration compared to a engle 110 cam. (which is used with stock rocker ratio)
