Old April 15th 2008, 13:21
elev8_dude elev8_dude is offline
My mechanic had said that I needed 1.25. However the cam size you referenced seems very familiar. Thanks for the reply. I'll have to double check my original spec sheet to verify my stated cam size. Any further suggestions are appreciated.
Just wondering, how much more horse power could one gain with rocker upgrades (if done correctly)
Old April 15th 2008, 20:39
Well, about 5 to 10% hp depending on set-up. In the build spec sheet on your first post it said you have a C35, this has slightly less lift and duration compared to a engle 110 cam. (which is used with stock rocker ratio)
