Old May 7th 2008, 17:36
speedy's Avatar
speedy speedy is offline
that is some bad luck jason , but i have every faith in your inginuity to overcome this minor setback and improve the original design
jon
woop woop
67 2276 turbo
64 ghia 1776
zx7rr
Old May 7th 2008, 22:12
No, I didn't just let all the air out of my airbags, this is what it dropped to...
I wonder if the welding was done on both sides of each vertical component it might have been OK...
Old May 8th 2008, 14:32
The break looks pretty clean ... almost as if the welding had not been completed in this area ?
It looks like it could be fixed with no redesign .. just proper welding. ?
Old May 8th 2008, 18:29
It is a very clean break, but the design is wrong too. I think had it been TIGed on both sides it would have been OK, but it is still a weak spot, there needs to be an extension of the current bracket to cover the side of the square tubing, not just the top.
Old May 8th 2008, 18:49
Panelfantastic's Avatar
I think the new ride height looks KEWL!
I think something very similar happened to the rear of the bus but I never got a detailed descrip or any pics from the guy that broke it. Glad you are taking it in stride, really just a minor development hiccup, yes? No real damage to the car or you?
Jeff-
No current VW projects
54 Chevy wagon LS2 AWD
56 Chevy Panel "Lost Cause"
VKG Bastage child
Old June 16th 2008, 03:14
Got her all fixed up a couple of weeks ago, but no GL forums!!!
Here's the welds, only about 30-50% welded through, so that was an issue, but really the design of the arm needed some help.
Here's the repair. The welds are pretty rough, I'm not that great a welder and it's MIG compaired to the old TIG, but I wager it will hang on a little better...
Old May 21st 2009, 08:22
aircool aircool is offline
Volkdent have you made any progress on your wish bone set up? I'm currently looking into getting the red9 unit.
