Old November 7th 2008, 12:26
I've seen a Porsche sender used in a standard bug before, the bolt pattern was near enough the same, just had to make up a spacer (about 2") so the tube sender doesn't sit on the bottom of the tank...
Old November 7th 2008, 13:53
helowrench helowrench is offline
how long does the sender need to be. a ghia sender may work, and they are the tube type.
(I have a spare that I can measure to compare)
Also, plug in your lever type sender to see if it works. You never know unless you try.
Rob
Old November 7th 2008, 18:23
Beautiful integration!
Old November 11th 2008, 15:40
kuna's Avatar
kuna kuna is offline
http://picasaweb.google.pl/krzysiek.kunicki/Dashboard#
3 photos, 1 early stage (aluminium construction), 2 foam shape done.
