turbo type 4
I was wondering if turbocharging a type 4 motor would be easier if I added an EFI system or if I kept with the carbs
Good question, anybody out, who has more experience with Turbo and injection? For my part, I can only say, that carbs work well, as long as they are adjusted properly and have no dirt inside. That would be the main reasons to go over to an injection system. Maybe another important point is, that you can get a much better overlook over your air/fuel mixture and you can richen your powerband at the correct timepoints. Hope, you can understand, what I mean!
Click here to mail me! |
I think FI is more reliable, especially for a Turbo setup. You definitely don't want an overlean condition. I see more and more Turbo cars switching to EFI for tunability and reliability. That's why I did it. The turbo cars at the track with carbs (that I see anyway) are breaking or malfunctioning more than the EFI cars. I will probably never go back to carbs. Just my opinion and preference. Also my EFI system also has ignition control so it automatically retards your ignition under boost and is programmable.
Julian '74 Super "If you are under control you're going too slow" - Parnelli Jones |
what are some EFI/Ignition systems that you might suggest I use for a 2.3l type IV engine that might go turbo one day?
The Autronic system is a nice setup - depending on your needs check out their website:
smc or the smc2 http://www.turbofast.com.au/autronic/autronic.html you can get the system from www.aircooled.net
Ken McMillion Shaka Intekanational http://www.shakaworld.com http://www.creativelydone.com |
I like the SDS because its compatible with almost anything. If you're N/A now and switch to a turbo, allyou do is change the Map sensor. You're probably better off going with the DIS option or run an MSD box. SDS is also nice b/c you don't need a laptop to program. You program from the compact programmer they provide. Also its a simple install. Take a look. www.sdsefi.com I bought it cheaper from my engine builder, also an SDS dealer. I can help you if you're interested. Good Luck!
My first taste
I got my first feel of a aftermarket FI this weekend. This was a motor that did not like traffic-fk87 2007 with ports I can almost fit a fist in. The FI conversion made it liveable which was unbelievable for us that rode/drove it before. I am starting a FI piggybank that I'll be hiding from the better half. -its nice to see some familiar names-SS
NICE!!! Its always good to have a stash "piggybank" for the toys. A man's gotta live too.
| Currently Active Users Viewing This Thread: 4 (0 members and 4 guests) | |
