Old May 14th 2009, 05:00
evilC's Avatar
evilC evilC is offline
Rich,
I presume those are push cylinders? Whose pedal box is it? Whats the lever ratio? Have you got a remote balance bar adjuster?
On mine I have lifted the floor in front of the original pedal cluster and found the ergonomics infinitely better. The void created is about 50mm so as to accommodate the (pull) m/cs in the future. I can't emphasize how much better raising the floor is. I have always thought that the bug pedals were too high and prevented fine and proper control hence the reason I tried it.
