Old January 22nd 2003, 15:02
Ross Morrison Ross Morrison is offline
Ricola, what I mean by aligned is, that if you were to draw an imaginary line through the top and bottom wishbone inner pivot points,(as viewed from the front),the pivot of the steering rack arms MUST be intersected by this line.
The other thing is.......why keep the front beam?
It is dead weight.I understand the need for a bolt on remedy, but if you are redesigning the front end ,you may as well do away with the factory parts and start from scratch.
