Old July 9th 2009, 18:13
RuleO9 RuleO9 is offline
These are my front brakes, disc from kerscher en calliper from porsche boxster
Sway bar from eibach and lowered spindels
The fit the rear rims i had to change the wider porsche 944 changed with the originele and changed the brakes with a set of kerscher..
So this was the view of the last few months..
Also front koni shocks..
And then offcourse the engine pictures..
Drilled at 104.. that's good for 2411cc
316°
914 cilinder heads..
With valves 48 and 40mm
Lightered en polised
BAS exhaust
44 webers with K&N airtake
