Old January 4th 2010, 22:34
hotsauce's Avatar
hotsauce hotsauce is offline
This has probably been covered
i searched and read threads for 3 days before finally posting here.
i acquired some Porsche 944 brake bits last week, for installation on my 65 bus. However on the initial test fit i found that the aluminum trailing arms in the rear will not fit inside the fenders of my bus without tons of modification that i am not capable of doing.
My question is this, will the rear discs come off these arms and bolt to the set of beetle arms i already have laying around? or do i need to find different brakes?
While im here, i may as well ask about the fronts.
i got the front and rear brakes off the same car. Based off what i have read on here, i have 86 and later brakes. Will the fronts bolt up w/ bearing spacers, and caliper mount adaptors?
Thank you in advance for any help.
-Jonny
just another square saltine.
www.garagejunkieapparel.com
