Old January 21st 2010, 10:22
kombi211 kombi211 is offline
brembos on my square
I have started adding a brembo brake upgrade on my squareback. 944 front hubs,993 front and rear rotors and brembo calipers from a 944t
I started the front as soon as I am done there will be moving to the back and doing a irs conversion and adding the alum arms from a 944,
hubs machined
bearing adapter and sleeve using vw inner and 944 outer
vw race installed
vw inner bearing and 944 outer bearing
test fitting hubs and rotors
test fitting calipers to see what i need to made for a adapter to mount them
used the mounting tab off of a set of 944 spindles just welded them to the stock vw spindles
Old March 12th 2010, 07:38
front is done now on to the rear
Old March 12th 2010, 20:36
Humble's Avatar
Humble Humble is offline
Looks great! How's the fit, any rubbing?
Old March 13th 2010, 11:37
Thanks everything fits nicely. the only rubbing i have is if i crank the wheels hard they tend to rub on the inner fender. but its not that bad. going to try spacing the wheels out a little more and see if that helps
Old March 16th 2010, 13:09
72marinablue's Avatar
Great idea welding the 944 caliper mounts to the stock spindles. Looks great!
1972 1300 GL In Progress
