The sleeves and springs I got from summit racing. I think all the part numbers are on the ultimate suspension thread.
Speaking of the big motor, I sent the spare case off for machining to bring the deck faces down. When I pre-assembled the motor to get deck height measurements I found the 3-4 side to be .020" taller so that will be evened out as well. Initial measurements add up to a .044" deck which will give me a 9.1:1 CR assuming a 59cc chamber. I'm going to measure those next to verify. A couple of notes: 1. New-ish rings are sharp as @#$&! and I sliced my fingers open pretty good 2. Using a wire wheel to clean the piston tops makes the garage smell like burnt toast |
A few new additions to the bug this weekend in preperation for the new drive train.
The street bug has been lacking gauges for some time and I finally got around to correcting that. A set of new Z-series autometer gauges now in the dash, 3 3/4" mini monster tach, oil press, and oil temp. ![]() ![]() I also moved a lighted switch for the electric fuel pump over with the other switches. From right to left, hazard, oil cooler fan override, fuel pump, HID driving lights. ![]() While I was leaning on the seat with my hands under the dash something in the drivers seat gave way. I haven't pulled up the seat cover yet but it seems like a weld broke. For now I stole a seat out of the race car until the other seat is fixed. Though after a quick trip to the store the stock seat may never go back in. ![]() I'm still waiting on an order from CB to build the motor, and I got word that the new tranny is shipping out today so it'll be here later this week. Might be able to put everything together next weekend! |
Finally got the rods I've been waiting 2 weeks for on tuesday, and thus began a long 2 days of motor build. Had to make a couple emergency runs for pushrods, rod bearings, and a fan belt but otherwise everything went fairly smooth.
Getting ready ![]() new rancho pro-street freeway flier put together and ready to go in ![]() mmm, straight cuts... that are surprisingly quiet, must be something with the CB gears. ![]() and about this time it was 2am and I had forgotten all about the camera ![]() The details: 2165cc CB aluminum case DPR 78mm crank Mahle 94mm forged pistons and cylinders CB 5.5" race rods CB #2246 cam, 260 dur. @ .050" .411 lift CB straight cut cam gears CB lightweight lifters Scat chromoly push rods Windage tray Scat wedge port heads, 40mmx35.5mm CB 1.3:1 forged rockers, measured out to 1.25:1 and .515" lift at the valve 30mm HD oil pump w/ filter 12 lb. lightened flywheel KEP stage 1 pressure plate The motor went together nice and easy. Had a bit of a scare when I tried to set the rocker geometry. The scat 1.4:1 rockers were uncomfortably close to coil bind and when I measured them out they were actually giving me a 1.32:1 ratio. I happened to have another set of CB 1.3 rockers laying around (I know right?) and I remember another builder saying they measured out with a smaller ratio. Sure enough, when I checked my set they measured out 1.25:1 which was good enough for .030" more breathing room at the valve spring. I got some help and we managed to swap in the motor last night. Couldn't do the cam break in until today and it sounds very mean. I had a little bit of popping so I know the carbs are a little lean so I'll sort that all out tomorrow. The motor is dry as a bone except a leak from the snout of the case, and the race car had a leak in the same area, grrr. The last problem I found while cleaning up tonight. I found the wing nut for the clutch cable on the tool cart, which means it's not in the car. Looks like I'll be back under the car tomorrow, but I still can't wait to drive it. |
