I just know right now the 71.5# max springs are waay too soft, loaded up with gear for a weekend, with no one in the car I can easily move the front bumper down an inch and hit the bump stops Do you think its necessary to run the helper springs up front with the 200# springs? Also, have you test fitted the QA1 coil overs with the 2.5" springs in the rear to see if the springs physically fit in the trailing arm?
1969 VW Bus 2.2L suby - Driving Daily 1302 EJ20 turbo Last edited by Eatoniashoprat; May 31st 2010 at 11:38. |
I'd suggest starting with the 200# springs in front and go from there. They might feel a little stiff without gear or a passenger but won't bottom out when you do.
Is it a helper or tender spring? A helper spring is usually very light (around 10#), easily compresses, and is only used to keep the main spring seated at full droop. A tender spring is a fair bit heavier and used to make a dual rate spring basically. A tender spring might be 50-70# and easily compress during high load but would smooth out the jarring ride of the main spring around town. Now with my setup I put coil over sleeves on the maxx strut body and with a 10" spring I found I need a helper spring to keep the spring seated. Using a 10" spring also gave me a fair bit of ride height adjustment. I haven't had a chance to fit the qa1 coilovers on the rear but it's a fairly simple affair. Just drill a 2nd 1/2" mounting hole higher in the cup, and locate the lower shock mount with spacers. For the top, drill out the upper mount to 1/2" (kafer brace too) and put the shock in place. I think sandeep but up some pics of the lower mounts for the qa1's. |
1969 VW Bus 2.2L suby - Driving Daily 1302 EJ20 turbo |
FYI, I did some calculations for something closer to Humbles setup (stiffer) to see what it looked like, this is what I found. Also, I made a little spreadsheet that I could email if someone wanted to check it out.
Front: 175lbs/in CPM = 113 Rear: Stock TB combined with 200lbs/in coilovers CPM = 126 F/R CPM difference = 10.5%
Here's my street car setup w/ full tank and driver:
LF 488 RF 437 LR 691 RR 633 Front: 925lbs. 41.1% Left: 1179lbs. 52.4% Cross: 1128lbs. 50.2% Total: 2249lbs. I run the 200# up front and i'm not sure what the CPM would be but I'd like to match it and add 10% or so CPM on the rear. You might be in the same territory with the subie swap. |
I think that's very close to my weight, I might be 50-60 pounds heavier but that's about it.
I went autocrossing for the first time last night and it was a blast, managed to turn some decent times but the front was on the bump stops the whole time and it understeered pretty bad unless you already had the back end coming around. It was a very tight course For 200# here are the numbers from my spreadsheet. For the coil over with the torsion bar I'm just adding the wheel rates, hope that's the right way to do it. I'd take them with a big grain of salt but here they are anyway. Front 200lbs/inch 121 CPM Rear stock TB 250 lb/inch coilover 134 CPM 10% difference Rear w/944 TB 250 lbs/inch coil over 139 CPM 13.1% difference
Mike, Do you know what your damper rates are? Are you running a rear anti-roll bar? You might find that stiffer dampers plus a rear ar bar might dial out your initial understeer. Personally, I intend to set mine up as a soft(ish - 100lb/in front 944N/A rear) with stiff damping as most of the roads around here (that are used for Road rallys) are fairly bumpy and I don't like the thought of the front skipping across the bumps particularly under initial braking.
In all of this of course lies the variation of conditions/use/driving styles that will give wildly different results. Clive |
