Old June 2nd 2010, 14:34
After tossing a couple of ideas around on were to mount my new shift light. I cut a plate to fit between the steering wheel and hub, drilled it up, painted it and mounted the shift light. I had to buy a 3 wire spiral cord and 3 pin connector so I can turn the wheel and allow the cord to stretch. I still need to wire it all in.
I got most of the engine bay wiring done. Still need to rewire the tag light and run a new pick to the third brake light. I cleaned up all the old wiring and ran everything thru heat shrink tubing, then wrapped it in nylon spywrap were it needed extra protection.
Still need to wire in the shift light, 2 relays for fuel pump and Mallory 6AL and wire the 6AL. I might need to wire in a Tach adapter if it does not work with the new CDI box.
My list is getting shorter. Only 3/4 of a legal pad page.
Old June 2nd 2010, 20:32
Wow, you got some cool touches going on. Hmm 3/4 page on a legal pad huh. I think my list is an entire legal pad . Keep going... I still have shotgun right?
Old June 2nd 2010, 20:44
Lazarus's Avatar
Lazarus Lazarus is offline
you will have to have shotgun cause thats all there is. i dont think he is handin over the keys just yet (even though more have driven my car in the last bit than ever b4)
Old June 2nd 2010, 21:00
When I (if I ever) get my car done there will be some people driving it too.
Old June 3rd 2010, 04:51
Yes a shotgun ride is still reserved for you.
Old June 3rd 2010, 16:39
speedy's Avatar
speedy speedy is offline
Dave ,
Looking very cool -as always .
Jonathan
woop woop
67 2276 turbo
64 ghia 1776
zx7rr
