901 Conversion HELP
I cannot get my bug flywheel to fit in the bell housing of my 901 transmission. Anyone ever had this problem. I am not sure if it is a diameter issue or there is something holding it out. HELP!!!
Keep Buggin 69 STD. 1776 CC |
Your leaving alot of info out. What year trans? You have a clutch and pressure plate on it? Pilot bearing good? Length of input shaft compared to bug trans? Clutch disc splines?
1970 T1 W/MassIVe 2913cc RAT/?EFI? w/direct fire (very soon) and 915 trans 1962 SC 1776cc SP 944NA brakes, 993 wheels VKG |
Thanks, I got it. Thanks to the help of Chug-a-bug. The year Transmission I was using uses the same flywheel as the stock 12 volt beetle so I had to make a mounting plate for the tranny to get everything to fit. Rolling again.
No prob dude... that's what we are all here for is to help eachother out
now we just got some Fine tuning to do. Chris.
