Old February 6th 2003, 12:05
Tim Tim is offline
Master cylinder bore size
Does anyone know what bore size of master cylinder should be used for following brake system configuration?
Front - Wilwood 4-pot calipers 44.5mm bore size
Rear - Wilwood 4-pot calipers 35mm bore size
I will be using Tilton dual mc pedal with balance bar.
Tim
Old February 6th 2003, 15:16
Superman
Steve C or H2OSB can do the calculations to answer this; however, a Wilwood rep. should be able to answer this on the phone.
