Old October 18th 2010, 08:22
judgie's Avatar
judgie judgie is offline
have a look into the hewland gearboxes, most of them have a hydralic throwout bearing. if you have a late style box then you can get a bearing that bolts onto the 3 bolt holes that are used to hold the support shaft. think tilton do them along with a few others.
Old October 19th 2010, 09:33
Tim Tim is offline
https://www.burtonpower.com/prod_fil...=70014&PSet=98
Found these on a Ford racing specialist website (UK).
The hard-copy catalogue mentioned that the hydraulic clutch cylinder nose (APC5) has overall depth 80mm from bearing face to mounting face and safe travel of 22mm. It also mentioned that several customers have successfully fabricated their own mounts on gearboxes other than Ford units. Not sure if this can be modified to fit late style T1 gearbox.
