Old December 16th 2010, 08:23
evilC's Avatar
evilC evilC is offline
Hi Alex,
The turbo came with two o/a depths of disc/drum 71mm and 100mm. To get a comparison with your 74mm dimension you will have to take off the thickness of the mounting face. The handbrake shoes are common across the 944 range so if your 178mm dimension is correct for one vehicle they should fit all models.
