Old January 9th 2011, 11:57
K9Dober K9Dober is offline
Thanks for your reply Spannermanager!
So, if I understand you right, I could use my 2" narrowed beam, using coilovers, dropped spindles. A friend of mine makes rear torquebars, and I've thought of making him fabricate one for the bottom front tube, and weld it in. If going for the t/b front, I'd fix the roll bar to the top tube of the t/b. I've got 8" rims for the front now, and reading your post makes me look for 5" inner rings to go for 7" instead. And would it be possible to make some kind of urethane disc to edge the bottom arms 5mms out in both sides, to adjust the camber?
Does this make sense?? :-)
Thanks!!
