#91
Hi Clive,
I did not calculate things, its just try and error and some eye-ball engineering. Keep us posted on your experiance with the MC"s Paul.
#92
When searching for a reference picture, I found some clear text about it: http://www.stoptech.com/tech_info/wp...g_valves.shtml |
#93
#94
Today I started on making the anti rollbar brackets, This anti rollbar started it's live on a pink "killer Kitty" opel.
![]() ![]() Paul.
If some is good and more is better, then too much should be just about right! Last edited by fahrvergnugen; May 21st 2011 at 15:04. |
#95
Guys, its not wise to mess with expensive changes in cylinder sizes from just pedal 'feel' alone without running the pads in on the fly for a good bit, it can make a huge improvement to the pedal height and save you chasing your tail, frame type sliding calipers need a lot of running in, personally, a mechanical balance bar is far preferable to hydro valves which also affect pedal feel, i don't like these and avoid them like the plaque, as Clive says, you shouldn't need both.
#96
First fitment test of the anti-rollbar, I think it needs a little modifications.
![]() ![]() Paul.
#97
Looking good again! Sway bars can be thicker then you think, so these may just be 'right'
![]() Maybe turn-around that tack welded bracket 180 degrees so you have more free room for the bar to move? |
#98
If you plan on going to the track regularly,then I´m sure you´ll find the right setting for just about any condition.I have 911 carerra 4-pot monoblocks up front and the 911 discs. In the back I have the standard 944 floating calipers and discs (temporarily).The proportioning valve alone should be enough for my intentions,at least for starters.I also have a 944 master cylinder,but may change it for a better more modern master cylinder.
#100
I am thinking of turning it 90 degrees, this way the uniball kan move freely. I moved the a-arm up and down and the sway bar does not hit a thing.
#101
Paul.
#102
Did some sway-bar work today
Welded the new sway-bar brackets to the upper front axle tube, narrowed the tube to the chassis head width and closed the end of the tube, this way I have some strenght in the brackets and still have the original body mounts. ![]() ![]() Test with 90deg. turned uniball. ![]() The 90deg. turned uniball works great, so I made a new bracket (needs some more welding). ![]() ![]() Put the grommet in and did a new test. The movement I can make without hitting anything is much bigger as the movement the shockabsorber can make. ![]() ![]() Paul.
#103
Bought myself a nice donor body, this '58 Will speed things up 8)
![]() Paul.
#104
Right side of the sway bar is now ready too.
![]() ![]() To make sure all the fittings of the fuel line are ok, I checked them with some air pressure. ![]() On original oval has special floormat fasteners, so I welded these back on the floor. ![]() ![]() Paul.
#105
Picked up the '58 donor for the oval today.
![]() ![]() Looking good. ![]() ![]() ![]() ![]() And a bus full of rust free '58 goodies ![]() It's almost a shame to cut this to pieces, but it will happen. :twisted: Paul.
Currently Active Users Viewing This Thread: 5 (0 members and 5 guests) | |
