Old June 5th 2011, 14:32
Picked up the '58 donor for the oval today.
Looking good.
And a bus full of rust free '58 goodies
It's almost a shame to cut this to pieces, but it will happen. :twisted:
Paul.
Old June 15th 2011, 14:54
Time to take out the old grinder again . I really need the parts for my oval, but still it was difficult to cut up this nice '58.
No way back now.
Paul.
Old June 19th 2011, 14:45
After a lot of drilling, the dash is out.
Paul.
Old November 30th 2011, 17:14
Between family live, work and some work on my daily passat, the oval is going forward as well (slowly).
Bolted the nose on the body, now i can see better what to do and where to do it.
It looks like the right is OK.
On the left I had some fitting problems, probably the welds from the pedalbox where to hot. I cut out the piece that did not fit and welded in a bigger piece instead.
Still needs some welding, grinding and sanding.
Paul.
Old December 10th 2011, 17:22
Today I started making the '58 parafan look like an '56.
Here is the difference between the '58 and '56.
Time to cut again.
Cutting, and trying.
The result of a few hours work.
Paul.
Old December 17th 2011, 16:51
Today I worked on the wipers again.
Just to be sure I mounted the mechanism and it fits. (sorry for the crappy phone pic's)
To mount the mechanism I had to weld this bracket as well
Paul.
