ok so I went back to the add in which I bought the parts this is the list of what I bought
- 944T Front and rear Brembo calipers - Bug front SS brake hoses - 944T Rear trailing arms with urethane bushings for bug - 4 944T brake rotors - quite rusty - I was going to get new ones from 944online. Up to you if you want these old ones. - 944T Front hubs engineered for 1974+ 1303 by VDub Engineering, with heavy duty caliper brackets - Installation instructions from VDub Engineering - 944T Spring plates + bug urethane bushings (944T rubber bushings removed) - 2 944 (non-turbo) Torsion bars 23.5mm - 2 1974+ 1303 spindles - Bug front wheel bearings - 2 Modified swans to hookup 1303 parking brake cables to 944T parking brake - 2 944T used rear shock absorbers (not shown) - Most all fasteners required to install this setup on 1974+ 1303 (not shown) I plan on using the turbo calipers up front, why wont the rear calipers work? also if the bias is so bad could I use a brake bias valve like the one made by willwood. also what is a tb cover plate? thanks for all your help |
