#106
cheers
yeah cnc machined. GT badges are becoming quite rare and a lot of money - i can get GT badges made if anyone wants one. (GT not the GTi one)
#107
Going back in time a little...
-Dave (who's project is currently at the "do I remove the strips" stage ;-) )
#108
Use the bonnet seal that attaches to the bonnet not the slam panel.
The original metal strip for retaining the seal is a pita rust trap. |
#109
Does that bonnet seal go around the top too? I ordered one for my 69 and it was too short to go all the way around the hood.
#110
no - i removed the old strip along the front scuttle - repaired the rust and then replaced the strip along the top - i had to buy the mexi seal (clip on one) and the standard one so i could trim it and use it along the top
#111
Thanks Mate!
#112
cheers
'72 Type 1 - GT '69 Type 2 - Bay |
#113
Pretty sure its a SACO unit that Deano has.
As per usualy I'm looking into MCs that will work with my current CNC slave and in future something else. |
#114
yeah Al is right its a saco unit. still havnt decided how to mount the slave - i will come to that soon!
Well i haven't made a whole load of progress over the last 6 months - but hte progress i have made has been pretty cool imo ![]() I've put my 996 seats in and fitted up black sun visors and rear view mirror which isnt exactly exciting but the front suspension has come on abit . The beam was narrowed 80mm back at the begining of the year but i wasn’t happy with the shock towers. I decided to design my own link pin style ones and have them made out of 8mm thick steel. The beam is now finished and together along with the refurbed brakes ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Gearbox, steering box and track rods need painting - wheels are going to be refurbed just leaving the interior. The car has been booked in the the trimmers for Jan. The conversion flywheel is currently being shipped from the US and then the engine build starts. Th countdown to VolksWorld show has begun!!!! Last edited by dub_crazee; November 20th 2011 at 09:31. |
#115
oops the pictures are huge! need to change it lol
#116
Well i picked up all the bits for my type iv tubo engine build and they now reside with rob RNJ motorsport.........i'm very excited about having and bug running again after 4 years
#117
well the deadline is coming around TOOOOOO fast with only 3 weeks to go until volksworld!!!
I've finished the brakes which are now all bled up - and the hydro clutch is fitted although does have a small leak i need to sort. We'l be spending all weekend at the bodyshop redoing a couple of bits im not happy with and refurbing the wheels and Rob is building the motor as we speak. i'm hoping it will all come togther very quickly! just a quick run down on the spec of the motor 96mm JE Pistons hardened eurorace barrels Webcam turbo grind case bushed for type1 lifters 55g super vee lifters 5 dowl 71mm crank kennedy 915 conversion flywheel H beam rods dry sump match ported to case CSP python exhaust manton cu to length push rods 1700 rockers 44x38 square port heads, stainless valves, cromoly retainers, LS650 springs, 55cc chambers porsche upright cooling it'l be run on carbs for the first year unutil my bank account recovers and i can switch over to efi turbo im getting rather excited now
#118
Sounds nice. I would be excited too.
#119
the bug is back now after being at the paintshop with craig until 430 sunday morning redoing a couple of bits i wasnt happy with and refurbing the wheels - pretty happy with how theyve come out!
![]() ![]() glad i went black caliper rather than red ![]()
#120
Looking forward to seeing it at ride height for the final look, wheels look good!
Rich
http://www.ricola.co.uk |
| Currently Active Users Viewing This Thread: 8 (0 members and 8 guests) | |
