Yeah, this one is actually going to be quite a bit of fun. I decided I wasn't going to do another car that I was driving at the same time as building, and it definitely feels way better knowing I can take the time to do it right the first time. Kinda tough to stay motivated when you walk downstairs and see just a huge mountain of work and a list longer then my white boards can handle...but once you start cracking on an item the work tends to flow pretty easily.
Years ago while doing a rebuild on my Audi Rally car a friend of mine noticed I had stalled out and implemented what is now known around here as "the one hour rule". Every day you have to spend a minimum of one hour in the garage, and you can't 'bank hours' (ie two hours today, skip tomorrow). You don't even have to touch the car, but I can tell you that sweeping and just sitting there gets boring real quick. So you start on something small and then suddenly it's 1am and you've plugged away for 6 hours. 1302 and 1303 pan halves are exactly the same, except for the seat mounts. I'm not 100% sure what changed up front on the frame head with regards to the steering box vs. steering rack mounts, but the '73 pan I have is identical to the '72 and '71 pans I have with the exception of the seat mounts. -Dave
| Currently Active Users Viewing This Thread: 1164 (0 members and 1164 guests) | |
