Old September 28th 2011, 18:30
On the removable apron, I've seen guys run an extra fender bolt between the existing two fender mounting points. They drilled a hole and welded a nut on the backside of the inner fender well, and added a corresponding thru-hole to the edge of the apron and fender (if that makes sense). In addition to the "pinch" of the existing fender bolts, the thru-bolt won't allow the apron to blow off. And the apron can still be removed without removing the fenders...
Kafer_Mike
Currently Active Users Viewing This Thread: 1159 (0 members and 1159 guests)
