#136
Also anybody out there running porsche ally a arms...
![]() we now have these.......... ![]() For mounting shocks made from en 30. |
#137
WOW! very Sexy....
LOVE the Carbon decklid Chris.
#138
I have a set waiting for me to rebuild my 1303, is this just a stud for mounting shocks? What does this do for me versus a normal bolt?
#139
This gives you a 3rd alternative for mounting the dampers as the top bolt is M10 and the Alloy arms have a M14 bolt IIRC:
1) Ream out the bottom bush insert to M14 (makes it a bit thin but workable though. 2) Replace the bottom bush insert with an M14 one. It preloads the rubber bush though 3) Use Lee's converter I used a combination of 1) and 2). Both 1) and 2) pre-suppose that the dampers have rubber or poly bushes, if you have spherical bushes then you have to use Lee's converter or similar or alternatively get special spherical bushes. Lee's converter would have been beneficial for me as I recently had one bottom bolt fall out, so this time around I locktighted it in. |
#140
typ4boy, how much are those shock bolts?
Are these bolts long enough for both a shock and a bolt?? I stumbled across a picture of similar bolts here on GL that appear to be much longer http://www.germanlook.net/forums/showthread.php?t=3943 Last edited by SportyBug; November 28th 2011 at 21:35. |
#141
52 shell 03 pan update she is rolling.........
#143
Nice work!!
#144
![]() ![]() ![]() brown car coming on.... |
#145
Thanks! |
#146
![]() Happy New Year to all the German look Freaks. |
#147
What is the progress on the front arms? More posts and pictures this year please!
#148
To busy to post much these days but here is the new shop car
#149
Good morning, does anyone have a pic of a interior shot with the side vents installed; with the back seat in?
#150
Wow! Very nice car Lee! What engine will it receive?
edit: saw it in the other thread: 2,1 150hp T4 |
